Door weatherstripping
Old Oct 17, 2019 | 12:43 PM
EOTWHH2's Avatar
Default Door weatherstripping
I asked the dealer what the part # is for the weather stripping that goes around the door on the body, was given 25910528. That doesn’t bring up anything when I search for it. Not sure if he was wrong.
was told the weather stripping seal around the door on the door has been disco. So Idk what to do? Is the seal from the 08-09 compatible? Is there a replacement part #? The parts guy was of no help. Hoping the Hummer community has the knowledge I’m looking for.
luckily the other seals I need that run along the roof from the front door to the back was located on Amazon
ps
i posted in a few other posts but on the off chance this get me the answer. I’m looking for a part # for the sun visor retainer on a 06 H2. Parts guy gave me 15877252 and that comes up for 08-09. Is it the same?
Old Oct 21, 2019 | 07:49 AM
ZackMan's Avatar
ps
EOTWHH2,
May I suggest you try this link: http://wholesalegmpartsonline.com
Go to Weatherstrips for Hummer H2. There is a number on the website that can be called as well.
Old Oct 21, 2019 | 09:13 PM
clsimmon's Avatar
GM 25910528 is not a valid H2 part. Also, unless your weatherstripping is torn, you should be able to remove, clean yours, and reinstall, even if it's been distorted. See the following thread: https://www.hummerforums.com/forum/h...artment-41554/
Old Oct 23, 2019 | 05:23 AM
wpage's Avatar
Been using "Shoe Glue" for repairs on my weather strip on my rig. Like the name imply s this adhesive is durable and stays flexible over time. May do the trick if you cannot find part needed.
dkb123
Jun 21, 2022 12:24 PM
Shiftrus
Sep 19, 2019 07:47 AM
Shiftrus
Sep 17, 2019 05:50 PM
DBLimo
May 8, 2017 06:33 PM
gotafish
Jul 19, 2012 11:18 PM
