Dash and windows out.
Old Apr 9, 2023 | 08:22 PM
Blackdeuce34's Avatar
Default Dash and windows out.
I have a 03 h2. For some reason the dashboard, radio, and widows quit working. The speedometer and tachometer still work. It also says unknown driver but will still run and drives fine. I've done the reset for unknown driver and it didn't help. If I put the car just in on position and not crank everything works. Anyone else had this problem?
Old Apr 10, 2023 | 08:03 AM
oceanbrave's Avatar
Hopefully an eagle-eyed member will have the exact answer, but in the absence of this history-wise consider the following:-
  1. What was the last work you did, any modifications, changes or replacements?
  2. Is there any aftermarket equipment such as an alarm, remote start, tracker etc.
  3. What is your battery's SOH (State Of Health) and SOC (Charge) ?
  4. Any water leaks or ingress anywhere (DDM PDM BCM)
  5. Air suspension - connectors, condition, any past issues?
A common link between the above issues is the "Classs 2 Serial Comms" e.g. the Instrument Cluster which uses it for most everything except the Speedometer and Tachometer, so does the DDM/PDM (Power Windows) and Radio
It sounds like a communications issue that only occurs when "HOT IN RUN" this a circuit that goes to a few modules which have serial comms, e.g.:-
BCM, HVAC, Air Suspension (the latter two can be easily unplugged to test)
It could be a failing module or a corroded/contaminated connector and may take a bit of detective work to trace.
Splice Pack 205 might be a good place to start, suggest watching
Hopefully this info is useful, so please feedback anything you find which could be useful to other members with similar issues.✔️
Good luck!
[Awaiting Resolution]
Old Apr 26, 2023 | 06:43 AM
oceanbrave's Avatar
Blackdeuce34 any luck?
martymrgrin
May 24, 2021 08:14 AM
kmcnattH2
Jan 22, 2021 08:16 PM
atari800
Jan 15, 2016 01:52 PM
Heart of chrome
Nov 28, 2014 07:51 AM
potroast
Dec 14, 2013 11:27 AM
