Climate control panel half works
Old Mar 14, 2020 | 02:38 PM
TacoDeMaiz's Avatar
Default Climate control panel half works
So the climate control panel doesn't light up on the left side. The buttons still work and so does the ac. Pretty much the lights just don't turn on. Could this be a fuse issue or is it most likely the climate control unit that needs to be replaced? If it's a fuse issue does anybody know where that fuse is located?
Old Mar 14, 2020 | 02:47 PM
Old Mar 14, 2020 | 02:52 PM
the bulbs are bad
Old Mar 14, 2020 | 05:40 PM
hummer_on_fumes's Avatar
It is the bulbs. It is pretty easy to take it apart and replace them. I did it on mine. You can even upgrade them to led if you wanted, I replaced mine with original bulbs
Old Mar 14, 2020 | 08:24 PM
beware using leds, reverse polarity will cause issues. New replacement discontinued, available as reman:
15832311 15832311
::::>19417498
mrvictory1999
Nov 21, 2020 12:14 PM
ltisdale
Apr 8, 2020 12:30 PM
Contract_Pilot
Mar 3, 2015 02:02 PM
Allen McGuire
May 3, 2014 03:08 PM
Davidio
Apr 30, 2014 02:46 PM
