Can't turn key on 2003 H2, ignition stuck
Key won't turn at all. Key is NOT stuck in ignition, it just won't turn the cylinder. I have two keys, the key is not the issue. Tried a graphite lube with no luck. A year ago when this happened the first time, I took things apart to see what was going on. I just kept wiggling things until the lock cylinder popped out a few millimeters from the steering column, and suddenly everything worked fine again. It's as if the lock cylinder was somehow pushed too far into the steering column. Fast forward a year to today, and it looks like the lock cylinder is again pushed in too far. I've tried everything to get it to pop out again, with no luck. I can't even remove the lock cylinder from the column since the key has to be rotated to release it through the hole on top. Anyone have any ideas? I thought maybe I could jerry rig some sort of push button start. So I popped the gear unit out from below the lock cylinder. I can rotate the gear and the Hummer will start, but it immediately shuts back off. Is this not working because the anti-theft knows that the key isn't turned?
Is that the white thing on the backside of the cylinder? I couldn't figure out what it was for. It has a gold metal piece on the bottom and a metal punch comes out of the top. If that's the lock solenoid, it is definitely actuating.
chanthaman90
Feb 22, 2018 08:35 AM
DanH3
Apr 25, 2017 11:39 AM
oregonK5
Jun 14, 2015 08:13 PM
Shayne100
Nov 18, 2014 05:22 AM
