Key not turning the ignition
Old Feb 21, 2018 | 09:52 AM
chanthaman90's Avatar
Default Key not turning the ignition
Hey everyone,
This isn't the first time with this issue, but this is what I am dealing with:
I put the key in the ignition and it doesn't move at all. I have had this happen 4-5 times over the past 10 years. It randomly does this for a week or so. Sometimes after awhile, I will finally get it to turn over after messsing with it for 15+ minutes, or a few days later, it finally will turn over. It is really frustrating. The battery seems fine. I have jiggled the wheel. I don't know what to do.
I have read that maybe I have a broken ignition lock, and may need a replacement. Any thoughts on this?
Old Feb 21, 2018 | 09:54 AM
Also, the key is not stuck in the ignition. It goes in and out, it just does not turn whatsoever. It is stuck in "lock" position.
Old Feb 21, 2018 | 10:13 AM
Sounds like a new ignition cylinder is needed to me.
Old Feb 21, 2018 | 02:53 PM
happythree's Avatar
tried SPARE keys? i had to use a new one
Old Feb 22, 2018 | 08:35 AM
You can try a tad of electrical safe lube, like CRC Power Lube. First on the key, wipe it clean, then re-apply, and a very small amount in the ignition lock.
Do NOT use WD40 or any other solvent (contrary to popular assumptions, WD40 is NOT a lubricant, it is a solvent).
More than likely, what Tainter said.
Amanda Reusch
Aug 30, 2016 09:24 PM
WheelingNDealing
Dec 7, 2014 05:02 PM
ingydrummer
Jun 24, 2014 07:16 PM
HERHMR
16
Dec 26, 2012 11:11 AM
hummerhonduras
42
Sep 19, 2012 11:49 AM
