Cambio bloccato hummer h2
Old Sep 10, 2020 | 12:50 PM
Andrea T's Avatar
Default Cambio bloccato hummer h2
Ciao a tutti, qualcuno ha avuto un problema come il mio? ( Hummer H2 2005 110.000 km originali )Facendo delle manovre avanti ed indietro in una stradina per inversione ad U, il cambio si e' bloccato nella R come spia nel cruscotto e retrocamera attiva, ma l auto e' in N e cioe' come fosse in folle e tutte le ruote girano libere.
Il motore non si puo' accendere perche' credo bloccato in R ( lo segnala il cruscotto ) e quindi inibita l accensione
Test effettuato con TEXA ma dice tutto ok
Grazie se qualcuno da un aiutino
Old Sep 10, 2020 | 01:43 PM
Ispezionare il collegamento del cavo del cambio alla trasmissione.
Old Sep 10, 2020 | 08:18 PM
Andrea T's Avatar
Grazie mille provo questa soluzione
ciao
Old Sep 11, 2020 | 10:43 AM
Andrea T's Avatar
YES YES!! RISOLTO!! ERA QUELLO!!...fatto una modifica e risolto subito !!GRAZIE MILLE ! Un Grande!!
Old Sep 11, 2020 | 12:13 PM
Ottimo, sei il benvenuto.
Old Sep 11, 2020 | 01:01 PM
Chrmer3's Avatar
Do you suggest doing this as a preventative measure since most of us are at 15 +/- years on a piece of plastic that failure seems imminent?
They also sell on amazon - (where I just ordered from)
Amazon Amazon
Old Sep 11, 2020 | 02:00 PM
You can check the current bushing, grab/shake the cable and see if there's a lot of play, at the bushing? If not, keep a bushing for backup.
Old Sep 12, 2020 | 08:05 PM
hummer_on_fumes's Avatar
I would definitely do it as a preventative or at least keep the bushing in your glove box. This problem can leave you stranded. Luckily when it happened to me I was in my own driveway
Old Sep 12, 2020 | 09:07 PM
same here. mine broke in the driveway. had to also replace the transmission range selector lever. the pin was also rusted bad and would not hold the new shift cable.
Old Sep 13, 2020 | 03:48 PM
Andrea T's Avatar
Excellent solution ... but I was out of town,,,,,, I solved it by welding a bolt and then closing with a double nut ... maybe it's the definitive solution ... I hope ... I got scared and thought the worst
I'm lucky to find this forum..yes yes
