Bump stops
Old Mar 5, 2021 | 12:11 AM
Volfan's Avatar
Default Bump stops
Alright guys looking for bump stops for an 05 with air ride suspension. Some of the Gm websites say they have 2 different part numbers a different number for each side. Other’s use the same part number for both sides. Before I order I thought I go here and utilize the knowledge you guys have. Joined a year or 2 ago. Most all my questions are already answered here by Mixman hummers Cali Phil or bronxtech or any other of the guys on this forum. For any of the newbies out there usually the is already here somewhere. There are some very knowledgeable guys here who are very helpful.
Old Mar 5, 2021 | 12:13 AM
Volfan's Avatar
Default Correction
Sorry hummerz didn’t catch the autocorrect
Old Mar 9, 2021 | 10:36 PM
clsimmon's Avatar
The air ride is keyed as a RPO code ZM6 aka Off Road Susp Pkg marketed as Rear Air Suspension. ZM6 has a bump stop part number GM 15062871 which you can no longer find. Coil Spring trucks (RPO Z83) have a bump stop part number of GM 15057984 which can still be found.
15062871 is a longer bump stop than 15057984; i'm assuming because if fully deflated this will give the air spring more clearance but I am not sure. I suppose you could still use 15057984 but it ride about an inch and half lower on those bump stops. I've never tried it myself.
Old Mar 10, 2021 | 09:18 AM
Volfan's Avatar
Thank you for the reply kind of let’s me know what I am up against
Old Mar 10, 2021 | 09:23 AM
Volfan's Avatar
Yes it is the ZM6
Justinh
Aug 29, 2019 06:21 AM
surfcityred327
Dec 31, 2018 07:55 AM
Blacksky
Jan 17, 2018 09:45 PM
Jayson DK
Feb 19, 2017 02:16 PM
alex2mil
Sep 22, 2013 03:44 PM
