Battery drain 2003 H2
Old Nov 21, 2020 | 01:24 PM
chevykev's Avatar
Default Battery drain 2003 H2
Anyone tell me the acceptable amp draw is ?
With radio fuse removed
Fuse refitted
After about a minute with fuse in
Old Nov 21, 2020 | 02:06 PM
MAX 0.05 Amp, or 50 mA.
Old Nov 21, 2020 | 03:12 PM
oceanbrave's Avatar
Drain obviously seems related to the radio.
0.06A is within the accuracy of DVM which is typically 1%+/- 1 digit so probably is 50mA
Note the H2 takes some time to achieve minimum current drain, several minutes if I recall correctly which maybe why you have different figures when the fuse is in.
It would be worth checking the circuit diagram to see what else is connected to the radio fuse as I don't think the radio is hot all the time.
Old Nov 21, 2020 | 04:46 PM
Retained Accessory Power (RAP) after timeout(approx 20mins), should be below .03amp.
Old Nov 22, 2020 | 07:39 AM
Chrmer3's Avatar
When this happened to me- I had installed an aftermarket bluetooth module that integrated into the radio & onstar wiring..Blue fusion I believe it was called...
so- anything aftermarket (alarms, adds, etc) start disconnecting there
Old Nov 24, 2020 | 07:26 AM
chevykev's Avatar
Default Thanks
Thanks for replies, it has an aftermarket previously fitted, slowly working through it, finding wires twisted together etc. No factory amp either. Steering wheel buttons don't work although there is a adapter fitted, but seems to be an obsolete one.
Mad Professor
Jan 16, 2025 08:13 AM
Alex DjFlaco
Oct 9, 2020 09:48 PM
Tab Tucker
Sep 9, 2020 03:57 AM
NIK1
Dec 6, 2013 06:51 PM
gbigstix
Apr 19, 2011 09:39 AM
