Air suspension question.
Old Nov 4, 2018 | 04:50 PM
MiBo's Avatar
Default Air suspension question.
Hi All,
I’m a fairly new H2 owner.
I have had some problems with the air suspension and have just changed the suspension sensors to new ones. I would be grateful if someone could explain if my air suspension works correctly.
Before I start the engine, the air suspension is at its lowest position. When I start the engine I could hear the compressor and the suspension raise about 7-10cm and then the compressor stops.
I think the suspension started at a much higher position before the sensors where changed.
Do they work as intended now, or should the suspension maintain it height when the engine is off?
Old Nov 5, 2018 | 06:49 AM
It should maintain its height when off..... You may need to find a shop with a Tech2 (or a GM dealership who will have one) to recalibrate the air suspension for the new sensors.
Old Nov 5, 2018 | 03:29 PM
MiBo's Avatar
Thanks!
I think i located the problem.
I also got a leak in te valve Part No. 19333035.
Old Nov 5, 2018 | 03:42 PM
MiBo's Avatar
Valve Part No.19333035
H206
Mar 31, 2019 04:52 PM
Random-Hero-
Apr 1, 2012 10:58 AM
crewj
Feb 28, 2012 09:30 PM
RedRocker
Apr 27, 2009 10:53 AM
GorillaH2
Feb 8, 2008 06:25 PM
