Aftermarket Headlight and Foglights
Old Oct 3, 2019 | 05:09 PM
WashMOH2's Avatar
Originally Posted by LoJac963
I have some 24 watt truklites I would sell but honestly the Amazon ones are just as good. I've been running them with the small DRL strips on the top and bottom of the light for a few years without issue. Also, for the DRL's I make my own out of standard 4.5" round LEDs using threaded rod, no hacking or cutting up the stock bumper.
Thanks for the tips. Have any pics of the driving lights by chance?
Old Oct 7, 2019 | 01:30 PM
LoJac963's Avatar
Check my build thread, I'm not sure where it is in it. Basically buy some 4.5" round LEDs on amazon or wherever, grind off the mounting boss, spray paint semi gloss black to cover the grind marks. The backs of them have 4 holes, you buy some threaded rod to fit, cut to length and with washers and lock nuts you adjust the aim and length and use the factory mounting holes by sandwiching the plastic between the washers/lock nuts. I hope that makes sense. Be sure to run silicone around the lens and the wiring coming out of the back. That is the only issue I've had with cheaper LEDs bought online, they will leak if not sealed.
Edit: Post 14 there are pics of the DRLs and how to make them
Old Oct 7, 2019 | 01:41 PM
WashMOH2's Avatar
Thanks a bunch!
Old Oct 9, 2019 | 11:43 AM
LoJac963's Avatar
No prob, let me know if you have any problems if you are going that route. It's a pretty cheap setup and works great and doesn't require hacking up the front bumper mounting points.
Old Oct 15, 2019 | 02:01 PM
kzoohummer's Avatar
I have 7" USA made Trucklite headlights, I bought the required H4 adapter but they fit without any modifications. They are great and have been in for 5 years now.
Are these the headlinghts you're referring to? [
LINK LINK
I know you mentioned getting the
H4 adapter H4 adapter
, but did you also use the Truck-Lite 98630 LED Headlamp Anti-Flicker Module Harness - PWM Pule Width Modulation Adapter? [
LINK LINK
Thanks in advance!
Old Oct 16, 2019 | 01:48 PM
LoJac963's Avatar
The ones I have installed are not the Truklites, those I have in boxes, they are 24 volt military lights.
These are the headlights I have:
https://www.amazon.com/gp/product/B0144EAHKU/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0144EAHKU/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
I believe they came with an adapter and I did not need an anti flicker
Old Oct 16, 2019 | 01:59 PM
did you have to cut and open up the rear of the headlight buckets to fit those headlights? many of those style LED headlights have a large backing that does not fit the standard hummer light buckets.
Old Oct 17, 2019 | 10:19 AM
LoJac963's Avatar
Yes I had to cut them out. I just used a huge rasp on a drill to open up the rear of the housing. If enough meat is left around the outside the factory housing will still work if for whatever reason one wanted to go back stock. Cutting the rear of the housing has no bad repercussions
Old Oct 17, 2019 | 12:48 PM
Agreed and from the inside of the hood you cannot even tell when the buckets have been enlarged. Can still put the OEM lights back in just fine too as LoJac says.
jsbihn
Sep 8, 2018 08:18 PM
Jerseyguy
Nov 8, 2012 10:34 PM
BlackOutH3
Mar 29, 2012 09:59 PM
tate2326
Jan 6, 2011 08:46 PM
cspringsh3
Feb 26, 2007 03:17 PM
