Advice on backup camera location
Old Oct 16, 2018 | 07:21 PM
Hbrezzi's Avatar
Default Advice on backup camera location
I was wondering if there is a better location for installing the backup camera other than the center of the rear bumper under the spare tire.
My backup camera is ready to be replaced as the image is very bright and blurry and I personally don't like very much the image with the spare tire blocking the top... Someone told me that there is a custom camera available on the market and it comes built into the center top marker light. I have not found it anywhere...
Any ideas or suggestions on where to place the new camera?
Thanks!
Old Oct 16, 2018 | 08:36 PM
LoJac963's Avatar
There is one which replaces the center marker light. I personally don't care for that one as having a light removed would kill my OCD. I put one in my hitch cover with a small screen ran to the front. I actually bought a much bigger camera I am going to be mounting in the center of the hatch at the very top looking down. I just haven't gotten around to it. You can save a ton of money from buying a generic setup and doing some wiring yourself.
Old Oct 16, 2018 | 09:06 PM
Hbrezzi's Avatar
Exactly! I was planning to do it myself. Are you getting one of those cameras that can tilt? I’d be curious to know if the spare tire isn’t much of an obstruction to the 170 deg view of the camera...
Old Oct 16, 2018 | 09:13 PM
Hbrezzi's Avatar
I’ve found this in a related post from 2008... this is probably what you said you wouldn’t do but, it doesn’t look too bad...
https://www.hummerforums.com/forum/g...ocation-10482/
Old Oct 17, 2018 | 11:00 AM
LoJac963's Avatar
This is close to the setup I have:
Amazon Amazon
I have a different screen which is in the left corner of the dash. The camera is wired into the reverse light so it comes on when shifting into reverse. As I mentioned, the camera I have now is junk which is why I bought the camera in the link above. Much bigger with IR LEDs and a wider angle of view. I also removed my tire carrier when I lined my bumpers because I was sick of it blocking so much view and having to open it every time I needed to get in the back.
Old Oct 19, 2018 | 11:17 AM
MiBo's Avatar
I 3d printed a plastic piece and fixed the camera to it, then I mounted the whole thing on the bottom of the center marker light.
I had to mount it that way, so I could back up to the trailer without guidance.
Old Oct 19, 2018 | 01:21 PM
Hbrezzi's Avatar
Sounds great! A good excuse to use my printer for something useful!
Do do you have any pics?
Thabks!
TeeStu
Jul 9, 2016 02:37 PM
kramcard6
Mar 8, 2015 09:41 PM
RenegadeMicro
Feb 9, 2011 09:05 AM
gahummer
Sep 14, 2008 06:49 AM
JeepeaterH3
Apr 23, 2008 02:15 PM
