Advice on backup camera location
I was wondering if there is a better location for installing the backup camera other than the center of the rear bumper under the spare tire.
My backup camera is ready to be replaced as the image is very bright and blurry and I personally don't like very much the image with the spare tire blocking the top... Someone told me that there is a custom camera available on the market and it comes built into the center top marker light. I have not found it anywhere... Any ideas or suggestions on where to place the new camera? Thanks! |
There is one which replaces the center marker light. I personally don't care for that one as having a light removed would kill my OCD. I put one in my hitch cover with a small screen ran to the front. I actually bought a much bigger camera I am going to be mounting in the center of the hatch at the very top looking down. I just haven't gotten around to it. You can save a ton of money from buying a generic setup and doing some wiring yourself.
Exactly! I was planning to do it myself. Are you getting one of those cameras that can tilt? I’d be curious to know if the spare tire isn’t much of an obstruction to the 170 deg view of the camera... |
I’ve found this in a related post from 2008... this is probably what you said you wouldn’t do but, it doesn’t look too bad... https://www.hummerforums.com/forum/g...ocation-10482/ |
This is close to the setup I have:
I have a different screen which is in the left corner of the dash. The camera is wired into the reverse light so it comes on when shifting into reverse. As I mentioned, the camera I have now is junk which is why I bought the camera in the link above. Much bigger with IR LEDs and a wider angle of view. I also removed my tire carrier when I lined my bumpers because I was sick of it blocking so much view and having to open it every time I needed to get in the back. |
I 3d printed a plastic piece and fixed the camera to it, then I mounted the whole thing on the bottom of the center marker light.
I had to mount it that way, so I could back up to the trailer without guidance. |
Originally Posted by MiBo
(Post 355406)
I had to mount it that way, so I could back up to the trailer without guidance. Do do you have any pics? Thabks! |
