AC issue. Actuator?
Old Jul 6, 2020 | 08:59 PM
  #21
you can read through this but milage may vary https://www.flashoffroad.com/Mainten...ioning/ac.html
Old Jul 6, 2020 | 09:49 PM
  #22
Good info. Many don't understand the pressure readings, max is the max after reaching operating temperature, not at startup.
I just did a 5minute vent temp check: My results: 91° (ac off) 40° (ac on) ambient 81°
Old Jul 7, 2020 | 11:38 AM
  #23
legerwn's Avatar
what year H2 are we looking at? Really need both high and low side gauge readings and the operating conditions they are taken at and have to know what the inlet and outlet temps of the evap coil are to get an idea of whats going on.
We can help but it will take some precise info or a good reputable shop may be able to sort it out.
Neal
Old Jul 7, 2020 | 02:15 PM
  #24
Since someone else just mentioned it in another thread and you mentioned the snowflake symbol..... just to be sure. On 2003 models only, if you see a snowflake symbol, that means the AC compressor is disabled. It has a thin slash through the symbol on 2003's. Since that was confusing they changed it for 2004 and later to eliminate the slash (on 2004 and later the snowflake symbol means the compressor is enabled).
Old Jul 7, 2020 | 02:32 PM
  #25
legerwn's Avatar
Do you have access to a dealer lvl scan tool?
It would be great to see the temp sensors in the duct indications and the blend door position (this is all based on you having the dual Zone AUTO system).
Neal
Old Jul 7, 2020 | 03:33 PM
  #26
bad_runner's Avatar
Ran another check today. 95 deg outside. Looks like it's about 52/53 psi. I'm just checking the low, I don't have all that equipment I'll let the shop sort it out I guess. So I checked at 10 mins. of running and 15mins and the picture attached is after 15 mins. It's still in the green and within the chart specs. But yeah I don't know what the high is.
On the snowflake, mine shows snowflake with the AC on and it goes out with it set off. I've had it flash before and turn off and I assume from what I've read about GM AC units is that is to protect the AC system because it's not within the correct temperature setting to be used. I've had it flash and go out and no AC when it was 65-70 degs out. I have never seen a slash thru the snowflake before but mines a 2003.
I've got a ODB II reader, that's it.
Old Jul 7, 2020 | 03:50 PM
  #27
bad_runner's Avatar
Well, I tried attaching img but it gets to 90 percent and stops.
Old Jul 7, 2020 | 04:08 PM
  #28
Resize pic then try again.
Did you remove some refrigerant?
Originally Posted by Eurynomestolas
@hummerz sense you mentioned my low was way to high I went on YouTube and watched a video and let the low refrigerant out until it was in the 40 range seems to be working!!! Here is the video https://youtu.be/Xx-bySr9edQ
Old Jul 7, 2020 | 04:22 PM
  #29
bad_runner's Avatar
Ok, this was when I checked today. 95 deg. checked at 15 mins. No haven't removed any coolant.
Just to be clear, it's a 2003. Snowflake showing the AC is ON. Off the snowflake disappears. I have no slash thru snowflake. Never seen that.
Old Jul 7, 2020 | 04:34 PM
  #30
You keep showing the same pressures, still too HIGH. Try this: connect your acpro gauge with ac on, then take your garden hose, and spray into the front grill back and forth keep spraying and watch your gauge to see if it drops. Post results.
