ABS/Traction Control Issues After New Brake Lines
Old Aug 31, 2023 | 12:07 PM
  #21
H2-SUT's Avatar
Fantastic Ptero, so happy you tamed the beast and now you can enjoy the fruits of your labor!
What you had to go thru just makes the victory so much better!
As far as the programming issue is concerned I don't believe it necessary on the earlier H2's, now if you had an 08/09 it's a totally different story the VIN needs to be programmed into just about every interface that hangs off the bus and another advantage to the older Hummers!
Old Sep 6, 2023 | 01:22 PM
  #22
Gavin Costigan's Avatar
Just out of curiosity did you have the engine running when you were bleeding the brakes? For the electric brakes, i know the ignition has to be on to run the pump.
Old Sep 7, 2023 | 10:10 AM
  #23
ThePtero's Avatar
When manually bleeding, it was off. But yep, for the Tech2 ABS bleed, it was running to turn on the ABS pump. This was on a 2007.
Gavin Costigan
Mar 31, 2022 09:04 AM
hummerz
Aug 17, 2020 10:59 AM
Neville Lazaro
Aug 5, 2020 01:30 PM
Raffi76
Jul 31, 2020 07:39 PM
f1ipX
May 5, 2014 06:59 AM
