37" vs 35" tires on H2
I ahave looked all over the internet and there isn't much with pics and description in the H2's regarding tire size and rims.
I prefer to keep it at a stock height by may do a front level if needed.
Does anyone have a pic of a H2 with 20x10's w/ 35" tires or 20x10 w/ 37" tires?
Marco
Marco
I will more likely go with a FUEL wheel. Looking at the Matte Black HOSTAGE 20x10's. I am going to see what are my options with a 20x11 if possible.
Also, grabbing a set of 2.5" keys for the front and 1" spring spacers for the rear for a small lift so that I can get just a couple more inches of space for some 37" MT tires
I am not sure about back spacing, but 37s fit without mods.
All vehicles are different & some will get a little rubbing at full lock in the front. That's it. Not that you don't want to go larger, but you'd probably be able to fit 38s easily. If you don't mind rubbin, even 39s might be possible. I've seen it, but that doesn't mean it's the best way to do it, either, lol.
Yes, I was going to go with a level because after I looked at the H2, the front is down quite a bit. I wouldn't mind it getting some more height in the fender wells, that's all. Try to make it look alittle different then the rest that is still rolling around. I wouldn't mind some 39" with a lift but I couldn't justify a lift kit. There kinda pricy haha.
38" with just cranked green keys, 2" rear coil spacers and 1" body lift.
Attachment 11100
Attachment 11101
Attachment 11100
Attachment 11101
Are those 20" wheels with 38 tires?
