2008 hummer h2 service traction control service stabilitrack and 4 wheel drive
Hi I have service four wheel drive and traction control and the stabilitrack on my dash and I hooked up my reader and it is saying code C0561-71 has anyone else had this problem and know what is causing this I e tried erasing the code and it comes right back don’t want to drive it so any help would be appreciated thanks
The cause is usually an incomplete signal from EBCM "Code C0561 comes in two forms. ... In this case, the electronic brake control module (EBCM) disables the traction control vehicle stability enhancement system. The code means the EBCM is receiving faulty data from other modules or is faulty itself. The most common cause is a defective ABS sensor or a corroded connector to an ABS sensor.
This has been covered before.. All I know is when mine said service four wheel drive on my 09 it was the Rotary Control switch on the dash.. BWTFDIK...It's happen twice and seems to be a thang with 08 and 09 and again WFDIK....But take the advice of the above posters... They are real "Mavens" ...You can Google that one.
650Hawk
Jan 2, 2016 11:42 AM
Veselka
May 21, 2014 02:12 PM
T REX
Sep 6, 2008 02:14 PM
