2008 H2 red N under the 4low
Old Jul 7, 2023 | 01:24 PM
Miketheike08H2's Avatar
Default 2008 H2 red N under the 4low
I’ve started seeing the red N on my four wheel drive switch randomly in the last couple days when I put my vehicle in park it stays on and only will go off if I cycle it into 4 wheel high lock and back to normal four wheel drive has anybody seen this in the 2008-2009 h2
Old Jul 7, 2023 | 01:30 PM
the switch might need disassembly and cleaning with some isopropyl alcohol maybe a bit sticky and activates when in park.
Old Jul 7, 2023 | 01:41 PM
I’ll try that. I’ve had my h2 since 2011 and never seen the red N come on before and its not throwing any codes so I hope that’s the case that it’s just dirty
Old Jul 7, 2023 | 08:11 PM
ThePtero's Avatar
Not sure on 08/09, but my 07 I had the red neutral light coming on often, but randomly with no codes. I ended up changing the actuator with encoder motor with part GM Genuine Parts 89059688 Transfer Case Four Wheel Drive Actuator with Encoder Motor. This was a couple of years ago and the light has never came back on since it was replaced.
Old Jul 25, 2023 | 03:11 PM
Same thing happened with the red N coming on and then when I tried cycling it into 4hi lock now it says service four wheel drive and won’t even go into normal 4 wheel drive mode
Red Bluff
New Member Area
Feb 7, 2022 06:45 AM
awburn1
Sep 21, 2015 10:47 AM
tbraly
Apr 19, 2014 08:36 AM
finall
Dec 20, 2008 06:11 AM
mr_rhino
Sep 29, 2007 03:24 PM
