2008 H2 electrical problem
Old Jun 24, 2021 | 11:57 AM
Christopher Ladd's Avatar
Default 2008 H2 electrical problem
My 08 has started acting weird. The key-in-ignition ding has a new pitch. Also, when I put my turn signal on there is a static noise through the speakers until a few seconds after it’s turned off. That same static is present when the radio is turned on. What does this sound like? Fuse box?
Old Jun 24, 2021 | 02:55 PM
HellHoof's Avatar
Sounds like a bad speaker. Door chimes and turn signal sounds are run through the radio and come out of the driver door speaker.
Old Jun 24, 2021 | 03:10 PM
interesting. Or the radio head unit. I have had suspicions that it’s not doing well. Backup camera is sometimes intermittent. I’ll look at speaker first
Old Jun 24, 2021 | 03:37 PM
HellHoof's Avatar
If it turns out to be the head unit and you go down the route of an after-market replacement, you'll find all the adapters and whatnot typically include or mention a "chime module". This is a box that goes behind your dash to replicate the chimes and signal sounds.
Old Jul 2, 2021 | 08:42 PM
H2-SUT's Avatar
If you have a stock radio and amp, chimes, onstar, navigation all come thru the drives door speaker. I had lost all my chimes and onstar and found that corrosion in the speaker connector was the problem. Removed, cleaned and used a dielectric grease on the connectors and bingo, good to go. If you find the speaker is shot or the connector on the speaker itself is shot acdelco has a factory bose replacement
15236987  15236987
which should fix you up.
Sergiog1
Jan 13, 2021 07:51 AM
justinw
Oct 31, 2016 11:52 AM
corvine
Oct 26, 2013 05:34 PM
glen4cindy
Apr 27, 2011 09:26 PM
ah_chu46
Jun 26, 2010 07:43 PM
