2006 hummer H2
Old Jan 24, 2021 | 09:23 PM
Barry Hammond's Avatar
Default 2006 hummer H2
Just bought 2006 Hummer H2, needs a battery. The one in it now has side posts and top posts. The top posts are for, ( I assume), the the led lights that are mounted on the front brush guard. There are wires connected to the top posts. The side posts have the main cables attached . The one in it now is yellow optima. But when I go to that battery the info says it doesn’t fit my vehicle. Question is what battery do I get that has both side and top posts?
Old Jan 25, 2021 | 08:46 AM
Whatever group size the Optima you have now is the size you will want. No battery selector is going to tell you that any battery with top posts will fit since no H2 ever came with a battery that has top posts. In this scenario you have a non-standard (the battery itself is standard, it is just non-standard for an H2) battery installed and will have to go with physical dimensions and terminal layout (some have positive on the left vs right) to find a suitable replacement. You can likely reference the model number of the one you have to determine its "group" size. Then just get a replacement that is the same "group" size making sure the replacement has both top and side posts.
Old Jan 25, 2021 | 09:05 AM
Thank you ,,MixManSC
Old Jan 25, 2021 | 09:31 AM
No problem. The "group" size is a standard set of physical dimensions and terminal layouts that all automotive battery manufacturers use. One thing I'd personally check is if the current group size battery has the approximate equivalent capacity in cranking amps and cold cranking amps as what the factory size has.
Old Jan 26, 2021 | 06:39 AM
fastNYsix's Avatar
They make various side post adapters that allow for additional wiring, if you decide to go with the stock group 79 battery.
dougie
Jun 22, 2020 01:13 PM
dougie
Jun 20, 2020 02:21 PM
BummerHummer
Nov 13, 2012 06:54 AM
cristalelectric@hotmail.com
Oct 19, 2012 08:41 PM
tsb
Dec 23, 2011 05:38 PM
