2005 Tail Lights and top lights not working on Hummer H2 SUT
Hummer H2For those who like a little more gleam to their Hummer, the H2 offers a similar rugged look as the H1, but as a lower cost, and with more added features, making it almost a massive luxury SUV.
Newbie girl here
I recently just bought a 2005 Hummer H2 SUT, its in good shape just needs some love, the tail lights and topp lights are not working, I tried looking for the fuse and couldnt find which one it was, so I checked all fuses under the hood and inside drive side console, all fuses seemed good, any idea's ...does anyone know which fuse it is..??
Is there a relay type fuse as well to check, I tried all google searches and also downloaded the Manual, cant find out where this fuse is, please help.... Thank You
Hmmmm…. Your top lights are your DRL (Daylight Running Lights) and they should be on their own fuse.
Are you front DRL working?
The front should be Yellow/orange the back are red.
You taillights have their own fuse as well.
Are your signal lights as your brake lights in the rear working fine?
I include the diagram of your fuse box as you can locate them and see if you got a current.
It’s always better just to switch out the old fuses for new ones.
As mentioned before check your bulbs.
you should have three on each side of your tail light, brake, signal and reverse.
Bulbs are new and brake lights and blinkers are working.
No top lights are wotking, no DRL lights seem to be working
If none of your DRL’s are working it can be as mentioned the fuse or a cable got pinched and you do not know about it.
Take it to a autozone or oReily as they can check your lights with a voltage meter.
