2005 H2 - Throttle Response Controller
Old Jun 24, 2024 | 02:34 PM
balbalas's Avatar
Default 2005 H2 - Throttle Response Controller
Looking for throttle response controller for 2005 H2 and I see most only have it for 2008+. Why is that? Also they call 2008+ as 1st Gen, then 2005 is what 0th Gen :-)
https://pedalcommander.com/products/...M0RgW1N_F7XexY
Old Jun 25, 2024 | 11:04 AM
Get a TB Port Polish, followed by a PCM tune, skip the band-aid. The pedal thing just advances the position of the TB in relation to your Accelerator Pedal sensor, you can do the same thing with your foot, jut push sooner.
A TB Port Polish increases efficiency and air flow, add an Intake for more. The PCM Tune will make more power and work wonders with AT Shifts etc.. to take advantage of those mods.
Good luck.
Old Jun 25, 2024 | 11:22 AM
balbalas's Avatar
Good luck.
Any pointer on who sells PCM Tune for H2?
Old Jun 30, 2024 | 08:25 PM
H2-SUT's Avatar
balbalas The 08 and later H2 use the new high speed canbus and items on that bus must comply to the new specs. 07 and earlier are all the low speed bus.
Here's the biggie, Forget the Pedal Commander, its just flat out a dangerous product, check out this youtube video to explain why:
Doc Olds gave great advise and the correct way to fix the problem.
Hbrezzi
Feb 6, 2020 10:58 PM
black beast
Nov 22, 2012 05:12 PM
benitobest
Feb 22, 2011 12:38 AM
JeepeaterH3
Jun 23, 2008 10:16 PM
Chinauoft
Jun 27, 2007 11:00 PM
