2005 H2 driver side door will not open
Old 10-26-2013, 08:38 AM
mcioci's Avatar
Default 2005 H2 driver side door will not open
At first I couldn't close the door. The latch was in the lock position so I had to hold door closed while driving to my house. Once the doors Locked automatically when I hit 10mph the door now locked on its own but since then I can open the door from inside or outside. What a pain climbing over the console 10x a day. Do I need to replace the unlock relay under dash? Would that just affect one door if it is in fact bad?
Old 10-26-2013, 09:34 AM
calif phil's Avatar
Have you tried to use the key to unlock it?
Old 10-26-2013, 10:36 AM
mcioci's Avatar
Yes that doesn't work either. It's weird, both inside and outside handles do not open door. Could it be the latch in door Sil is broken?
Old 10-28-2013, 08:22 AM
calif phil's Avatar
I would take it to a body shop. They are good in with problems like that.
Old 10-28-2013, 05:07 PM
mcioci's Avatar
I'm bringing it into my friends body shop tomorrow. I will post what the issue was. Thanks.
Old 11-01-2013, 11:05 AM
accely's Avatar
It's probably the latch that connects to the door handle. I've had this come off a few times after I replaced my handles. I finally used gorilla glue and wrapped it in gorilla tape and it never came loose again.
Old 11-02-2013, 08:53 AM
mcioci's Avatar
That's exactly what it was. Thanks.
pauly1052
06-27-2015 04:51 PM
TxHummer07
03-22-2015 11:02 AM
chasekanter
01-29-2011 11:15 AM
FurbiesAndBeans
06-09-2010 10:58 AM
davetrader
05-22-2007 07:30 PM
Quick Reply: 2005 H2 driver side door will not open
