2005 H2 driver side door will not open
At first I couldn't close the door. The latch was in the lock position so I had to hold door closed while driving to my house. Once the doors Locked automatically when I hit 10mph the door now locked on its own but since then I can open the door from inside or outside. What a pain climbing over the console 10x a day. Do I need to replace the unlock relay under dash? Would that just affect one door if it is in fact bad?
Have you tried to use the key to unlock it?
Yes that doesn't work either. It's weird, both inside and outside handles do not open door. Could it be the latch in door Sil is broken?
I would take it to a body shop. They are good in with problems like that.
(Post 303726)
It's probably the latch that connects to the door handle. I've had this come off a few times after I replaced my handles. I finally used gorilla glue and wrapped it in gorilla tape and it never came loose again.
Originally Posted by accely
(Post 303938)
