2005 H-2 Weather Stripping Replacement Help
Old Feb 7, 2020 | 11:51 PM
Rickomatic's Avatar
Thanks for the info Bronxtech
Old Feb 8, 2020 | 09:41 PM
clsimmon's Avatar
Those rear quarter panel weatherstrips tend to twist. I found if you use 3m Black Super Weatherstrip 0360 as glue to hold down the twisted part, it works amazing. That stuff is magic and sticks directly to the sheet metal. You will need to hold it in place for about 2 min to ensure you have it placed where you want it. Then, just masking tape it down for the night leaving the door open (in a garage). By the next morning it's placed perfectly back as if it were new.
Old Feb 9, 2020 | 08:24 AM
sean04h2's Avatar
Default Door weather strip
Hey Rick
I have original sets of 4 door weather strips came from my 2004 H2
I'm sure it will fits on 05 h2
you can contact me if you'd like to offer $$ (408)621-3632
Old Feb 10, 2020 | 07:56 AM
Another tip once you remove them and get them cleaned up is the weather stripping has metal in it on the part where it goes over and grips the metal lip on the vehicle. Before you put it back on squeeze that metal inside the weatherstripping back closed some to make sure it grips properly. That part often gets the metal inside pulled open a bit too far when removing them. Also as bronxteck mentioned, once you get them very clean its a good idea to add some silicone spray to the outside of them (wait until after you have the reinstalled so the silicone does not prevent adhesion) to give them some added protection.
Edit to add - I checked and the inner GM truck weatherstripping (at least for a 99-07 pickup is not quite the same. On our H2 there is a flap part of it that goes to the inside that the one for the trucks does not have....
Old Feb 11, 2020 | 05:53 PM
Rickomatic's Avatar
Hey Guys, I just got back form a long business trip and saw all the posts. Thank you again Simmon, MixMan and Sean. I went over to the shop today and we are making great progress. I'll send some pics soon if anyone is interested.
Old Feb 11, 2020 | 05:57 PM
Rickomatic's Avatar
Hey Sean, thank you for the offer, I'm sure those would have worked on my 2005 but my son in law had ordered some while I was gone on my trip. I'll remember your offer and willingness to help.
Thanks,
Rick
Old Feb 12, 2020 | 07:43 AM
sean04h2's Avatar
Default Weather strip
No problem rick.
Old Aug 19, 2023 | 09:31 PM
MuseumMansDaughter's Avatar
i am going thru the same thing right now, need all 3 pieces for both front doors, and man they are salty,,,,
fozzie21
Oct 19, 2022 05:19 AM
black beast
Nov 22, 2012 05:12 PM
Raydon254
Jul 26, 2012 02:45 PM
mossy
May 16, 2010 11:45 AM
Chinauoft
Jun 27, 2007 11:00 PM
