2003 H2 BCM problem
Old Jun 18, 2020 | 06:30 PM
Vmgreen0110's Avatar
Default 2003 H2 BCM problem
My H2 BCM board has gone ou . Cant be repaired. Any help would be great. US dealers dont have it.
Old Jun 18, 2020 | 08:24 PM
get your hands on a tech 2 scanner and pick a bcm from the junk yard. reprogram it to your vin
Old Jun 18, 2020 | 09:01 PM
Default Nothing in junk yards
Have been looking everywhere. Will a generic online that fits a 2003 to 2007 work on it.
Old Jun 18, 2020 | 10:34 PM
it still would need programming to your vehicle's vin number with a tech 2 scanner no matter where you get one.
Old Jun 19, 2020 | 07:03 AM
Default Will It work
Why am i told it had to be exact match. Are they wired different.
Old Jun 19, 2020 | 07:44 PM
different years have different features. the GM part number does need to match unless GM has superseded the part with a newer part number revision.
looks like there might be a few that interchange
Units Must Be Flashed On The Vehicle; Vehicle Specific On-Car Programming Must Be Performed After Install To Prevent Drivability Issues
OE Number:
10367690
15136271
15198179
19369690
15137393
Old Jun 20, 2020 | 09:59 PM
Default BCM 15194423 is on my bcm.
15194423 is the part number on my comtrol. Not available through GM. Been on back order sence march with only updates is there is no update. Cant find at any parts house or even eba .
Old Jun 20, 2020 | 10:22 PM
Remanufactured Body Control Module
Application Summary: Chevrolet 2007-03, GMC 2007-03, Hummer 2007-06
Replaces Original (OE) Part #
10367690
10383536
15064149
15116066
15136877
15137393
15137394
15137395
15137396
15167328
15194170
15194423
15198116
15257043
15257044
15257045
15257046
Old Jun 20, 2020 | 10:30 PM
the dorman replacement covers all these models
10367690, 10383536, 15064149, 15116066, 15136877, 15137393, 15137394, 15137395, 15137396, 15167328, 15194170, 15194423, 15198116, 15257043, 15257044, 15257045, 15257046
more details on - https://www.dormanproducts.com/p-72563-502-007.aspx so most likely once programmed with the hummer update software any of those modules would probably work but if you cant find the original then an aftermarket is an option
https://static.dormanproducts.com/do..._tech-note.pdf
jcwitney and summit racing seem to have the dorman. but you have to send in the old module as a core if not 200$ extra
one of the forum users is parting out an H2 maybe he has a module for sale.
​​​​​​https://www.hummerforums.com/forum/p...art-out-42425/
Old Jun 20, 2020 | 11:07 PM
Yet,only $50 core charge on the 19369690
