2003 H2 BCM problem
My H2 BCM board has gone ou . Cant be repaired. Any help would be great. US dealers dont have it.
get your hands on a tech 2 scanner and pick a bcm from the junk yard. reprogram it to your vin
Nothing in junk yards
Have been looking everywhere. Will a generic online that fits a 2003 to 2007 work on it.
it still would need programming to your vehicle's vin number with a tech 2 scanner no matter where you get one.
Will It work
Why am i told it had to be exact match. Are they wired different.
different years have different features. the GM part number does need to match unless GM has superseded the part with a newer part number revision.
looks like there might be a few that interchange Units Must Be Flashed On The Vehicle; Vehicle Specific On-Car Programming Must Be Performed After Install To Prevent Drivability Issues OE Number: 10367690 15136271 15198179 19369690 15137393 |
BCM 15194423 is on my bcm.
15194423 is the part number on my comtrol. Not available through GM. Been on back order sence march with only updates is there is no update. Cant find at any parts house or even eba .
the dorman replacement covers all these models
10367690, 10383536, 15064149, 15116066, 15136877, 15137393, 15137394, 15137395, 15137396, 15167328, 15194170, 15194423, 15198116, 15257043, 15257044, 15257045, 15257046 more details on - https://www.dormanproducts.com/p-72563-502-007.aspx so most likely once programmed with the hummer update software any of those modules would probably work but if you cant find the original then an aftermarket is an option https://static.dormanproducts.com/do..._tech-note.pdf jcwitney and summit racing seem to have the dorman. but you have to send in the old module as a core if not 200$ extra one of the forum users is parting out an H2 maybe he has a module for sale. https://www.hummerforums.com/forum/p...art-out-42425/ |
Yet,only $50 core charge on the 19369690
