08 H2 service 4×4, stabilitrak, traction. Remote start not working
Old Jan 10, 2025 | 01:02 PM
Uncle Creepy's Avatar
From: Florida (pregrave yard) going back to My house in NH
Default 08 H2 service 4×4, stabilitrak, traction. Remote start not working
Hey All, I searched everywhere and can't find much on this.
I have a 2008 H2 base.
All fuses under the hood checked out good. It runs & drives in all gears OK. Reverse OK. Recently replaced grommet to shift linkage & trans fluid looks good, but about a week of driving the lights came on & the dial for 4x4 light blinks in all settings but, it won't stay on.
Also the remote start doesn't work anymore... Any clue ?
thanks in advance....B
Old Jan 10, 2025 | 03:31 PM
if it is an aftermarket remote start i would check the wiring under the console. maybe bad wiring to the ignition.
as for the 4x4 maybe the encoder motor needs cleaning or replacement. or not enough power from issue 1.
Old Jan 10, 2025 | 07:28 PM
Scan ALL modules and post the codes.
Old Jan 11, 2025 | 08:40 AM
calif phil's Avatar
Remote start is disabled if the CEL is illuminated.
Old Jan 11, 2025 | 01:01 PM
H2-SUT's Avatar
Grounds! or 12v power distribution
Old Jan 13, 2025 | 09:20 AM
Default Got codes scanned....
Found nothing even though dash is showing 3...
Old Jan 13, 2025 | 12:21 PM
SCAN ALL MODULES! O'Reilly only scans the PCM.
Old Jan 15, 2025 | 08:28 AM
Gavin Costigan's Avatar
you need to go buy a tech ii scanner that will scan everything. Otherwise just take it somewhere. Almost impossible to diagnose abs/traction control without a good scanner
Old Jan 15, 2025 | 09:39 AM
HellHoof's Avatar
Could be a wheel sensor, could be a module, could be a ground. Having the vehicle scanned by a shop will give you an idea where the fault lies. The AutoZone / O'Reilly scanners only scan for Check Engine light codes, not the rest of the vehicle's modules.
Old Jan 20, 2025 | 06:48 AM
Default Thanks....
I guess I have to pay a shop 100's of $ to figure it out.
I hope it's the dumbass switch/dial.
