05 hummer spare tire swing arm
Old Mar 29, 2019 | 08:05 AM
alan33's Avatar
Default 05 hummer spare tire swing arm
Will factory swingarm spare tire off 2005 h2 bolt onto a 2005 h2 SUT?
Old Mar 31, 2019 | 10:14 PM
clsimmon's Avatar
Yes, all OEM h2 carriers are the same from '04ish to '09. They were built by SMA, offered in '04 as a dealer option, '05 as a factory option.
Old May 13, 2020 | 09:24 PM
Larry Nichols's Avatar
@clsimmon - I recently purchased a swing arm tire carrier for my 2005 H2. The carrier is 3 bolt on the hinge mount, but bumper/existing tow hook mount is 2 bolt. Do you know of any stability issues when mounting with only 2 bolts?
Old May 13, 2020 | 09:44 PM
clsimmon's Avatar
It's unusual you have an '05 and it does not have the factory outside spare, or the 3 bolt holes for the outside spare as it was introduced that year. I've been told you can use the swing-away without the 3rd bolt without any problems but clearly Hummer engineered it to have three.
Old Jun 16, 2020 | 04:23 PM
Jason Pip's Avatar
I have an 02 H2 and the swing arm is very difficult to rotate. I have greased it but no good. Any idea the make so I can research replacing the bearings?
Old Jun 16, 2020 | 07:56 PM
Chrmer3's Avatar
i would bet moisture got in between the pivot point (where the grease would pack) and caused some slight corrosion. The arm simply should lift out of the pivot point. If I remember back on my 2003 I used a jack to help lift it up and out. It is very heavy - make sure tire is off and still expect approx 50 pounds approx if I recall. Once out clean it with emery cloth and re grease. Once you put back In should be like new again.
Old Jun 17, 2020 | 03:04 AM
Jason Pip's Avatar
Thumbs up
Thank you sir....huge help.
Old Jun 17, 2020 | 05:17 AM
oceanbrave's Avatar
For ref
This is what it looked like before being cleaned up
Old Jun 17, 2020 | 06:11 AM
oceanbrave's Avatar
There's a locking-bolt locking the groove at the bottom, the inner bearing sleeve i beleive is phosphor bronze.
Also, there is a rubber seal at the top, mine was "shot to bits" so as I couldn't find a replacement I used the original metal part of it with a large O-Ring and tucked inside, figured it couldn't be any worse.
Old Jun 17, 2020 | 09:19 PM
Chrmer3's Avatar
I know was some years back but I think the first version 2003 simply sat in place from weight. I dont recall a set bolt - however that does make sense to have and may of been on a later revision.
Treviso
Feb 11, 2016 08:31 PM
tharber
Jun 19, 2015 07:21 AM
Billarmao
Sep 15, 2014 10:57 AM
tharber
Aug 6, 2014 02:50 PM
meh1510
Jun 27, 2011 09:43 AM
