08 hummer h2 misfire
Old Jun 17, 2020 | 09:56 PM
afatouraee's Avatar
Default 08 hummer h2 misfire
hi everyone, i have a 2008 hummer h2 sut that has a misfire on cylinder 7. it’s not enough to through a code but when idling or cruising at highway speed with low rpms around 1500 i can feel the misfire and the car feels like sputtering but when i press the gas pedal it goes away. i have changed the spark plugs, wires and put a new coil as well still same issue. did compression test and it has same compression as other cylinders. i did replace the injector with another cylinder and still no difference. the fuel pump is new and pressure is within factory specs.
i’m truly puzzled and any help will be appreciated .
afatouraee
Jun 19, 2020 05:54 PM
juicebox123
Nov 27, 2018 12:38 PM
dlmx
Dec 17, 2016 09:50 PM
norinco3264
Feb 9, 2015 05:00 AM
CrindoTech
18
Dec 18, 2011 03:41 PM
