05 H2 Drivers Seat Won't Adjust Up and Down??
Old Jan 28, 2016 | 03:26 PM
amayer40's Avatar
Default 05 H2 Drivers Seat Won't Adjust Up and Down??
I have a 2005 H2 and all of a sudden the drivers seat won't move up and down. When you press the buttons you can hear a faint click so it's sending a signal to the motor, just not moving. Back and forth are working, seat back and lumbar are working, just up and down. Any thoughts?
Old Jan 29, 2016 | 04:45 PM
fnfal308's Avatar
Mine did that. I put some pressure on the shaft with pliers while moving the up/down button and it stated moving. I must have been stuck. Both front and rear up/down on the driver seat did not work. this fixed both - been working for a year.
Old Jan 29, 2016 | 05:32 PM
amayer40's Avatar
Awesome! That with a little WD40 I got 1 of 2 going again! I will keep working on the other but at least i don't feel like I'm sliding off the seat. THANK YOU!
Old Jan 30, 2016 | 06:20 PM
fnfal308's Avatar
I was also sliding off the seat. That is the worst feeling trying to drivr
Old Aug 23, 2018 | 06:42 PM
07H2STL's Avatar
Default 07 same problem
would love a bit more detail on how to make that fix you described.
Old Aug 26, 2018 | 02:59 PM
amayer40's Avatar
From what I recall I just went to the bar that moves the seat and really lubricated it. Then as I was tiring to use the button I put some good force on the seat bottom upward and it started moving again. It was almost as if the gear was stuck.
Old Aug 27, 2018 | 07:14 AM
07H2STL's Avatar
Thank you very much!! Really appreciate it!
Liz Gutierrez
Mar 5, 2017 09:14 AM
mp51998
Nov 29, 2015 09:02 AM
hmer
Mar 24, 2015 05:02 PM
NC_Hummer
Dec 22, 2012 11:48 PM
Quijy
Oct 20, 2008 07:30 PM
