05 H2 coolant leak by cylinder 7 area
Old Mar 16, 2022 | 08:42 PM
  #71
Gadget? Get a plug and play $150 >>>>> SCANNER: GM General Motors Diagnostic Scanner Code Reader ABS SRS SAS Scan Tool Vident
iLink400 Full System Single Make Scan Tool is the most cost-effective professional multi-system scanner that delivers OE-level diagnosis for all electronic systems of different car brands. The vehicle coverage includes 1996 to 2019 Chevy, GMC, Cadillac, Buick, Pontiac, Saturn, Chevrolet Truck, Chevrolet MPV, Pontiac APV, Hummer, and some selected 2019 models. The manufacturer is continuing updating the software to cover the latest vehicles. It has not only the basic functions such as reading/erasing codes and live data, but also advanced functions including actuation, adaptation and programming. In addition, it ensures you to access the most commonly required service features like Oil Service Light Reset, Throttle Body Alignment, Electronic Parking Brake Service, Battery Configuration, Steering Angel Sensor Calibration, CBS Correct, and others.
It reads and erases Diagnostic Trouble Codes from most (if not all) electronically controlled systems, including Engine, ABS, Airbag, Automatic Transmission, Immobilizer, Climate Control, etc.
Answers for Frequently Asked Questions on Functions:
Engine:
  • Crankshaft position (CKP) relearn
  • Camshaft position (CMP) relearn
  • Oil life reset
Transmission:
  • Preset transmission adapts
  • Reset transmission adapts
  • Reset transmission oil life
ABS:
  • Automated bleed
  • Brake press sensor calibration (for changing sensor)
  • Yaw rate sensor recalibration (for changing sensor)
SIR/SRS:
  • Setup new SDM (for changing new SIR/SRS ECU)
  • Setup SDM primary key in BCM (for changing new SIR/SRS ECU)
Others:
  • Copy and paste TPM information (for changing new Romote Control Door Lock Receiver ECU)
  • Tire type / Pressure selection (for changing new TPMS sensor or for changing new tire)
  • Program Key Fobs
Rkendallgtp
Jul 10, 2021 02:36 PM
Alex DjFlaco
Oct 8, 2020 07:10 AM
armando99
Oct 16, 2019 04:15 PM
Brodie
Oct 2, 2008 09:29 AM
dizzy
Apr 22, 2008 09:34 PM
