03 HUMMER H2 issues .
Old Oct 28, 2021 | 08:32 PM
mr.murphy2525's Avatar
Default 03 HUMMER H2 issues .
I just purchased A 03 Homer H2, and my RPM won't go past 2000 . My MPH works fine. Just trying to find out what type of good advice I can get before I go to a actual shop?
Old Oct 28, 2021 | 09:07 PM
H2-SUT's Avatar
Default Looking into a very dark tunnel with no flashlight!
Any addl info, Check engine light, pop's sputters, gauge info, all normal readings. In park tapping the gas, can you get the RPM's to go over 2K, Do you have access to a scanner? How many miles? I guess at least it runs, thats a start.
Old Oct 29, 2021 | 08:03 AM
calif phil's Avatar
Need more info, is it running fine and just the tach that is not reading right? In that case a cluster repair will be needed, if it is not revving over 2000 RPM, I would suspect a clogged catalytic convertor.
Mr__Mayhem
May 3, 2017 02:09 PM
Pdmiller
Sep 15, 2012 10:20 PM
Germanbuilt11
Sep 4, 2012 09:21 AM
hairco
Jun 1, 2010 12:09 AM
