2006 H2 Hummer leak
Old Sep 14, 2021 | 06:52 AM
CiscoH2's Avatar
Default 2006 H2 Hummer leak
I could really use someones assistance on an annoying water leak that is happening above the drivers side front windshield. Water is slowly dripping from inside the weld bead line underneath the windshield. I have had the windshield experts reseal the windshield, which was not the issue but had it done anyway. Have had two "expert" water leak experts and currently working with one at the GMC dealership to find this leak. I have removed the headliner so one can better see where the water is coming from but no one seems to be able to figure it out.
I am the original owner and it has never been wrecked.
I am hoping someone may have insight on what it could be or what is happening. I took a video during a rain storm but cannot seem to load it to the site so one can view.
Old Oct 2, 2021 | 12:17 AM
NOSZ06's Avatar
Default Roof markers
Check all roof marker light seals
Old Oct 8, 2021 | 01:32 AM
jimf350's Avatar
Same exact thing happened to me, It is the body seam seal under the cargo rack plastic were the corner lights are! You will have to take off the luggage rack to access.
Old Oct 8, 2021 | 07:26 PM
H2-SUT's Avatar
Check these locations.
H2's leak at the following locations: Under marker lights due to bad seals, sunroof where the drains are plugged or the drain hoses have failed. Roof body seams that run the length of the roof from under the clearance lights in the front to the rear. And some have indicated that a badly installed windshield also.
In my experience with my 3 H2's the problems are usually a clogged drain hose or the clearance light leaking.
Old Oct 8, 2021 | 10:07 PM
jimf350's Avatar
I replaced my window 2 times before figuring out the body seam, it just looks like it was leaking from the window
Old Oct 29, 2021 | 05:07 PM
HarleyWrase's Avatar
How about the rain gutter 3M sealant tape.. do you see cracking in any part of the tape seal? This would be my bet.
Old Oct 29, 2021 | 05:08 PM
Exactly what I was betting on
trevortcaruso
Jul 18, 2024 01:07 PM
UK_Hummer
Sep 15, 2021 09:50 PM
drmeek
May 9, 2013 10:20 PM
Timothy L. Holt II
Oct 10, 2012 05:47 PM
djezhutch
Apr 27, 2011 08:24 AM
