03 h2 hesitation when hitting gas
I have a 03 h2 and when I'm at a red light the engine acts like it wants to die. When you hit the gas there Is hesitation and it sputters some. I haven't got any codes or has the check engine light came on. Once up to about 60mph it runs smoother. Have changed the plugs and cleaned throttle body. Could the fuel filter be fouling?
Try disconnecting the wire to the mass air sensor. If this clears up the sputtering try cleaning the mass air sensor, carefully with the correct cleaner. If cleaning then doesn't fix it replace it.
Good Luck!
Good Luck!
clsimmon
Apr 5, 2018 08:01 AM
HuMmErDXB
Jan 21, 2008 02:21 PM
