$3800 whoops while having fun
Well, it looks like I've just joined the club... broke my front diff while going through 2 feet of snow to get to my Mom's place, delivering gasoline for her generator and other supplies... Need the whole case with gears, if anyone can help, please let me know... Thanks!
I was going up my mom's driveway (about 300 feet long, uphill). Got a run from the road, got about halfway up, and heard a loud "Bang!" under the front end... backed down by the road where it was clear and saw diff fluid dripping off the skid plate...
I had the same thing happen to me... had the front freewheelin going up an incline... soon as the front wheels touched down the front diff exploded and ripped all the gears to bits. I removed the front driveshaft, diff bits and sideshaft (except the CV going through the hub, to keep the wheel bearing together) and capped the transfer case. Select 4 high (or low) and off I went. Have done about 10k miles since. Problem is I work in Angola and stay in SA, but neither has any support for H2's. If anybody has a used unit I can buy, and are willing to ship it to SA, I will really appreciate it.
It is an aluminum case. After speaking with other H2 owners they told me you can remove the front drive shaft and not loose fluid out of the Transfer case. I have not tried it but i am going to ask the mechanic if it is true. So if i run into this problem again I will be able to tackle the problem easier. I have also picked up a used front diff for about $200 that has 20k miles on it just in case i break another one. I can truely say that this will not stop me from wheeling and I will return to Carnage Canyon to tackle that beast trail that took me out but I will be more prepared.
The difference being that I had some shale collapse under me and centered mine on a rock which put a nice crack in the case.
Teh Corona Dood
05-05-2012 08:46 PM
FilthyKings
04-19-2012 08:39 AM
joewcob3
12-01-2008 12:01 PM
BlackTiger
09-24-2006 03:03 AM
importkiller
07-20-2006 04:11 PM
