Wheels
GT Hummer Products sells a nice wheelset that is factory approved at hummer products dot com. 16.5" , 17" and 18" and they are "normal" wheels that tire shops will work with. Plus they are CTIS compatible.
Another option is the 2500/3500 dodge ram alloy wheels from the mid 00's, they don't have an exact match in back set but it's pretty close, within 1" of the hummer OEM. There are two versions a 5 spoke 8 lug and a 6 spoke 8 lug.
Or you can get the 17" factory OEM alloy wheels by hutchinson and just remove the runflat and any tire shop will work on it [that's what I'm using currently.
One problem with aftermarket wheels is there is a possibility of hitting/damaging the hood under full suspension compression or the rear fender.
Discount Tire removed my old tires and runflats and mounted new GY MTRs without runflats. You need to give them inflation tank valves for balancing if you have CTIS
Or you could buy a used wheels set for a fraction(1/4) of the price from this guy(below) and use Uship.com to get them
Rallequip.com Used Military Tires and Equipment
BMoney5327
05-07-2012 07:36 AM
sdot425
09-14-2011 09:04 PM
hilljob26
09-26-2007 05:00 PM
diamondh2
01-11-2007 11:10 PM
