Help solve a mystery that has stumped 5+ mechanics. (P0236, P0238)
Old Jun 6, 2025 | 09:07 PM
BigBoyHummer's Avatar
Arrow Help solve a mystery that has stumped 5+ mechanics. (P0236, P0238)
Help solve a mystery that has stumped 5+ mechanics. (P0236, P0238)2000
Hummer H1 6.5L Turbo Diesel
After the check engine light is cleared, during heavy acceleration such as full throttle, getting onto a freeway I first start to experience, fish biting, a delay, and then acceleration delay and acceleration. This will go on continuously unless I back off the throttle. Then I start to hear somewhat of a low level roar. It sounds as if maybe the waste gate is letting most or all of the boost pressure escape. Then I get the check engine light and reduced power. The codes produced are P0236, and P0238.
Replaced:
PMD
Map SensorT
urbo waste gate solenoid & actuator
Turbo Boost sensor
History:I initially took my Hummer in to SHOP A due to a rough idle for the first 15 seconds on startup as well as some white smoke. They replaced the fuel injection pump, PMD (at my request), injectors, and glow plugs. This solved the 15 second rough idle.After I got it back, I got a check engine light during acceleration.
I took it back to SHOP A, then received it back saying that they had fixed it.The check engine light returned, so I took it back into SHOP A . The mechanic said he was going to install some sort of very-able pot. After they said it was fixed again I received it back. Check engine light again. I then noticed they had left the wires to the PDM dangling and a bunch had been severed.
I took it back in to SHOP A and pointed out the wires had been severed. The mechanic told me not to worry and that the makeshift pot they had put on completely bypassed the PMD. Hearing that, and then seeing how they had just taped on the pot, and glued it in place sent up big red flags.I asked them to fix the wires, and reconnect the PMD. I do not know if they did this correctly. I asked the check engine be fixed one last time. It was not.
I then took it up to SHOP B. To try and fix the check engine light, they replaced the turbo waste gate solenoid and actuator. This did not solve the issue.
I then took it to SHOP C and they removed the pot and reverted it back to stock, and replaced the MAP sensor. This did not solve the issue either.I switched PMD's back to the old one, still no luck.
Donald Austin
Oct 28, 2018 05:43 AM
Tony Ritale
Aug 10, 2013 03:02 AM
quadblaster240
Mar 29, 2013 02:34 PM
01H1
Dec 3, 2010 10:00 PM
sns
Dec 22, 2009 10:43 AM
