got my hummer today - maintenance question
Old Mar 9, 2022 | 05:51 AM
Jerry06's Avatar
Default got my hummer today - maintenance question
I received a beautiful 2006 alpha. Any obsessed people here with regards to maintenance
I just drove it to my garage so havnt driven it much yet but here are my observations and your advice much appreciated
1) drain filter light is on ( I have been reading to drain it but where exactly is the drain). Does the light go away right after i drain it - any drainage procedures
2) my first diesel and I noticed when I started it and put it in park the rpm’s rise (cold engine) and when I tap the gas it normalized - is this because it’s cold or filter light? Is it common.
Any maintenance of special attention to things not mentioned In maintenance schedule?
it’s a low mile example hummer
Old Mar 9, 2022 | 07:48 AM
What is "low" mileage? Did you get service records with it? If not Mike Sabaresse at Tustin GMC in Tustin, CA. can pull them up for you. He is one of the premier H1 techs in the country. If real low mileage, meaning it hasn't been driven much over the years any rubber seals become suspect. Fuel light should go out after the filter is drained. You might want to check with Dave at hummerpartsguy.com and get the maintenance manual if you did not get one with the truck. The Alpha is amazing. I was lucky enough to own two of them.
Old Mar 9, 2022 | 07:04 PM
Jerry06's Avatar
Yea it’s has 9100 miles - plan on keeping it low mileage
I noticed some paint chips that where touched up where the seems meet (wagon style) I heard it’s common
Any signs that would indicate it’s been off road a lot?
Old Mar 10, 2022 | 07:07 AM
Not necessarily.
Old Mar 10, 2022 | 10:57 AM
Jerry06's Avatar
Default Gas tank
How does the two gas tanks work
- should I just fill main tank
- if I flip the switch for reserve and no gas does engine quit?
thanks
Old Mar 10, 2022 | 04:28 PM
Any engine without fuel quits running. I always kept fuel in both tanks and switched back and forth between them as one or the other ran out.
Old Mar 10, 2022 | 04:48 PM
Jerry06's Avatar
What tank does the fuel gauge read?
Old Mar 14, 2022 | 06:17 AM
ggt667's Avatar
thanks
Fill both tanks as those are separate, when you flick the switch from main to aux the meter should change its source as well, on mine the meter only works when on the main tank, and goes all the way down when I flick the switch to auxilary.
Old Mar 14, 2022 | 07:49 AM
The fuel gauge should be accurate regardless of which tank you have selected.
Old Mar 21, 2022 | 12:58 AM
M4ch1n3's Avatar
congrats on the Alpha! 9100 is brand new wow.
I got my first Alpha last Sept and was my first diesel too. Was a learning experience with the truck overall but good info on internet for just about everything and what’s missing, the forum members have been great.
Where about are you located? I’m in SoCal and at Cars and Coffee with the Alpha most Saturday mornings.
Also, on topic of fuel, something I learned (and seems to help; feels better) is adding some diesel fuel additive EVERY fuel up. It’ll help keep things clean and lubricated. I use Power Service Diesel Kleen (gray bottle) and add a bit to both the main and aux tanks on each fuel up.
