Engine light
Old Mar 22, 2020 | 10:05 AM
Justin Lee's Avatar
Default Engine light
My engine light came on yesterday after refueling. About after an hour drive. It has not been an issue. The gas tank cap seemed tight with no issues. How long does it take to go out it that is the issue? I opened it up and tightened it back up. I just refueled the main tank. I’m just trying to eliminate root cause.
thanks
Old Mar 22, 2020 | 02:08 PM
Paranormal's Avatar
A check engine light does not reset by it self. You need to plug in a code reader into your OBDII plug and pull the code to see what the problem is.
If this was an H3, I would tell you to tighten your gas cap and inspect your charcoal filter.
After reading this thread, I happened to come across some additional info. I read that if you run very low in fuel, your CEL will come on and it will reset itself after several engine cycles. So if this is the reason why your CEL came on, you're good. I would not risk it and see what code is stored in the computer.
Old Mar 24, 2020 | 08:09 AM
What year is your truck? Might not have an OBD port.
Old Mar 24, 2020 | 11:04 AM
Justin Lee's Avatar
1998 h1
Old Mar 25, 2020 | 01:52 PM
You have one. Under the dash left of the steering wheel.
Mr_Fulano
Jul 15, 2012 03:05 PM
NIK1
Sep 15, 2010 08:54 AM
ralylark
Mar 7, 2010 09:35 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
lynnhasahummer
Nov 24, 2008 03:17 PM
