Air-conditioner
Old Nov 26, 2019 | 06:29 PM
cesar23w's Avatar
Unhappy Air-conditioner
Need help please.
My 2002 wagon's air conditioner only works on the high setting. No air comes out of the first three settings. Anyone experience this problem? What could be the cause?
Old Nov 26, 2019 | 06:39 PM
I didn't know "wagons" had an air conditioner? Many vehicles have a problem with the resistor.
Old Nov 27, 2019 | 08:04 AM
cesar23w's Avatar
Thank you for suggesting the resistor. The part is reasonably priced so I will definitely be willing to try that. It looks like you may have solved my problem! I'll keep you posted when the product comes in.
Old Nov 27, 2019 | 12:30 PM
Paranormal's Avatar
Try checking your fuses first before replacing the resistor. If I remember correctly, the high speed is on a different fuse than that of the other speeds. Check fuses 6C and 7C
Old Nov 27, 2019 | 05:01 PM
Monka's Avatar
Also, ( after checking fuses) check the connection to the resistor harness... corrosion can also make the fan not wokr
Starboy0720
21
Sep 20, 2017 08:58 AM
iPhone
Dec 8, 2012 07:54 AM
Landon
Jul 1, 2012 03:17 PM
Wrdabney
Sep 15, 2009 11:09 PM
hummer
Jun 26, 2008 07:30 AM
