Head and Valve Issue
Old Jul 24, 2007 | 12:58 PM
  #91
Dennis's Avatar
Default RE: Head and Valve Issue
Do you have a K&N and did it run bad?
Old Jul 24, 2007 | 01:29 PM
  #92
HummerGuy's Avatar
No, it ran fine, and yes, I do have K&N, but this isn't the MAF, it's the MAP. Two different things. The MAP measures air pressure in the engine, not air flow.
Old Jul 24, 2007 | 01:31 PM
  #93
Dennis's Avatar
Really..Interesting, didn't such a thing existed....Thanks for the clarification
Old Jul 24, 2007 | 01:36 PM
  #94
HummerGuy's Avatar
I didn't either, until I got the MAP error message on my OBDII scanner. Mike had it replaced. I'm going to pick it up in a few hours. I had that, the rear fluid sprayer motor replaced , the warped a-pillar covers (again) replacedand the loose half-shaft checked. I'm in line to get the new one, whenever GM decides to make the damn replacement part [&:]
Old Aug 2, 2007 | 11:48 AM
  #95
a04h2's Avatar
chevy colorados have had the same cylinder head issue
Old Aug 2, 2007 | 11:56 AM
  #96
HummerGuy's Avatar
That figures. And then GM was playing dumb when it first happened. You think if it existed in one car with the same engine they would acknowledge it earlier. They probably thought they had it fixed, or maybe it just happened with the '06 Colorado's. Interesting
Old Aug 2, 2007 | 01:59 PM
  #97
RealJeep's Avatar
Hi Group,
Just bought my H3 in May and the steering column is clunking but that's another thread. My question is...Did GM fix the head and valve problem or is it still an issue? Mine is a 2007 (Late Production) with the relocated window controls.
Old Aug 2, 2007 | 09:34 PM
  #98
a04h2's Avatar
there is either a tsb or campaign to replace the cylinder head on this issue. if i understand correctly the exhaust seats are loosening from the head.
intogaming
Jul 7, 2012 08:52 AM
xroperx
Head and Valve Problems.
170
Apr 13, 2009 07:46 PM
monicauw
Jan 25, 2008 11:18 AM
SUPER_CHEVY
Nov 20, 2007 05:19 PM
Linus Gump
Jun 21, 2007 12:53 PM
