2007 hummer h2 steering and braking noise
Old 05-31-2013, 04:43 PM
big_red_machine's Avatar
Default 2007 hummer h2 steering and braking noise
Trying to figure out where this shuddering/rattling noise is coming from. When I turn the wheels in either direction there is a rattling noise also when I push on the brake all the way that same noise appears.
Wne I do both at the same time the noise is even louder and more violent. Steering fluid os full.
Just had service steering fluid topped up with oil change and front and rear differential service. 153k on the h2.
Old 05-31-2013, 04:45 PM
I'm also still able to turn the wheel with ease and the brakes still work.
Old 05-31-2013, 10:40 PM
Just removed the belt and checked the pulleys, everything is moving smoothly. Also looked underneath the truck and couldn't find any loose components or leaks.
Old 06-02-2013, 08:56 AM
Removed skid plate last night, couldnt find any signs of evidence of leaks.
Old 06-02-2013, 09:10 PM
Trying a power steering flush tomorrow
Old 06-02-2013, 10:19 PM
No more Jeeps's Avatar
If its a shudder clunking its either bad frame mounts or motor mounts.
On my old 2007 H2 I had bad frame mounts. That cured the noise problem.
Old 06-03-2013, 07:04 AM
I'll take a closer look. Thanks for the reply.
Old 06-04-2013, 10:38 AM
Power steering flush completed. No change.
Old 06-04-2013, 01:49 PM
HUMVEH2's Avatar
Check the shield its probably rubbing against the rotor.
Old 06-04-2013, 06:46 PM
Could you please elaborate
Quick Reply: 2007 hummer h2 steering and braking noise
