2007 hummer h2 steering and braking noise
Old May 31, 2013 | 04:43 PM
big_red_machine's Avatar
Default 2007 hummer h2 steering and braking noise
Trying to figure out where this shuddering/rattling noise is coming from. When I turn the wheels in either direction there is a rattling noise also when I push on the brake all the way that same noise appears.
Wne I do both at the same time the noise is even louder and more violent. Steering fluid os full.
Just had service steering fluid topped up with oil change and front and rear differential service. 153k on the h2.
Old May 31, 2013 | 04:45 PM
I'm also still able to turn the wheel with ease and the brakes still work.
Old May 31, 2013 | 10:40 PM
Just removed the belt and checked the pulleys, everything is moving smoothly. Also looked underneath the truck and couldn't find any loose components or leaks.
Old Jun 2, 2013 | 08:56 AM
Removed skid plate last night, couldnt find any signs of evidence of leaks.
Old Jun 2, 2013 | 09:10 PM
Trying a power steering flush tomorrow
Old Jun 2, 2013 | 10:19 PM
No more Jeeps's Avatar
If its a shudder clunking its either bad frame mounts or motor mounts.
On my old 2007 H2 I had bad frame mounts. That cured the noise problem.
Old Jun 3, 2013 | 07:04 AM
I'll take a closer look. Thanks for the reply.
Old Jun 4, 2013 | 10:38 AM
Power steering flush completed. No change.
Old Jun 4, 2013 | 01:49 PM
HUMVEH2's Avatar
Check the shield its probably rubbing against the rotor.
Old Jun 4, 2013 | 06:46 PM
Could you please elaborate
