Re: Gear shifter / aftermarket
I'm not sure if this is the correct category /thread area, but I guess the gear shifter handle (aftermarket) falls under 'interior?' [sm=bangbang.gif]
Anyway, I purchased a aftermarket gear shift handle.. I replaced the OEM, and all seemed well until after driving a bit I parked and couldn't get the key out of the ignition. I assumed that the shifter was ever so slightly not allowing the vehicle to be in "park" completely.. It takes severals tries (approx 6-8) moving the shifter - either all the way forward, or back just a bit, before the key releases.. Has anyone else had any issues like this? I really don't want to go back to the OEM, and eat the cost of the shifter handle, but I also don't want to eventually destory the ignition or something else.. Any ideas - very much appreciated.
RE: Re: Gear shifter / aftermarket
How is that little plastic cover that goest UNDERNEATH the shifter and covers the shifting "stuff"!
I know that is hard to understand, but hopefully you get the jist!!!
I know that mine was a little ***'D up once and it was a chore to move the shifter.
HummerGuy
02-12-2008 01:53 PM
Wu Jen
04-02-2007 10:07 PM
