Rattling hummer no more
If anyone has a 2003-2007 hummer H2 and your doors rattle beyond I have the fix for you. Has anyone heard of Dynamat? I bought a box of Dynamat on Amazon, it came with 9 pieces. I put these in each door and the covers that are on both sides of the dash which contains the fuses because they were rattling as bad as the doors. My truck now drives like a new truck. No more noise from doors. It rides like a brand new truck now. The Dynamat costed me $144 but it's well worth it trust me.
Can you explain a bit more?
You took off the interior door panels and the fuse box cover?
I seemed to identify my squeaks coming from where plastic pieces over lap on the doors. Like where power window buttons are. My passenger power window button area was actually broke and quite loose but I hot glued it and it reduced interior noise significantly. I do hear a few squeaks when I hit bumps but I am sure it is interior pieces rubbing against each other.
I am not going to hot glue everything that squeaks.
Since I am the prime driver and love the truck, I hear and feel little things. I'll ask passenger "do you hear that?" and get "hear what? you're nuts"
you def have to be gentle and I am not so I got my interior guy to remove the panels and put them back on for me.
I read (somewhere) that the glue (or gloop) that holds credit cards on paper in the mail, can be pulled off and pushed into squeaky areas. If you need to remove the panel, the gloop just comes off.
This is a good article - thanks
Just to add to this, i had my whole H2 stripped and covered in a similar material to dynamat. This was done more for an audio install, but the doors received the heaviest treatment. The difference is quite staggering. On the freeway you still hear the buffeting from the wind given it's as aerodynamic as a hippo, but in traffic or low speeds, you can listen to the radio at half the volume it was. No squeaks or rattles, it just feels solid. First time i ever used sound deadening. Will be doing it for all my vehicles going forward.
Good to know it worked! I have some similar material to dynamat and this mod/improvement is on the to-do list.
For any of you wanting to see what the doors look like underneath the panel (at least on my '09) there are some pics on my install thread. My doors were covered on the inside and outside of the door shell and on the inside skin with comfortmat (similar product to dynamat) and also on the back of the panels in places. We also used a fabric layer (for isolation i think) in between the panel and the door card. I also thought about putting it on the underside of the hood too, to keep it quiet but am not so sure re temperatures etc...
BabyTank
10-12-2011 06:07 AM
OnAll4s
05-06-2008 08:26 AM
