coolant leak !!!
Old 06-13-2014, 10:04 PM
a7m1's Avatar
Default coolant leak !!!
so after a month of owning (what i assume carefully driven 2009 i5 hummer h3) not really sure about maintainance
43,500 miles
while doing tb cleaning, after i wa done just topped up all fluids
well, later smelled this funny coolant burning smell, ignored it, then saw coolant resercoir dropping ignored it too, since the weather is too hot and i overfilled it so i thought some evaporation and descardig of overfilling by that tiny hose or whatever,
3 days later still smill that funny smell, well it wasnt little coolant burning off due to filling
the level is still decreasing
and while the car still warming up, looked under the hood and its dripling(ac off)
the leak was on the plastic peice on top of the radiator nextto the radiator yellow sticker warnings
killed the car and went inside typig this thread !!
puxtures in attachments
so is this common failure???
the car didn't overheated thankfully
Attached Thumbnails coolant leak !!!-20140614_055141.jpg   coolant leak !!!-20140614_055122.jpg   coolant leak !!!-20140614_055111.jpg
Old 06-13-2014, 11:07 PM
a7m1's Avatar
sorry my image is not clear, captured usig mobile device( couldn't add arrows to indicate location)
here's pic i found on the internet showing the exact location
do they sell the plastic peice? as oem part? or the whole rdiator assembly has to be purchased?
i assume this is common problem right?
thanks
Old 06-14-2014, 07:29 AM
happythree's Avatar
# 1 next to tires. search and you will find hundreds of comments,,maybe thousands
Old 06-14-2014, 05:33 PM
a7m1's Avatar
Smile
since this happend in my posession it must be common problem (the car was driven very nicely)
my main question is weather that plastic leaking part sell standalone? or comes is assembly
what do you mean #1 next to tires?
forgive me that i didn't search i was really upset about this situation
thanks alot
Old 06-14-2014, 07:50 PM
BERULAKIDE's Avatar
Number one replaced part on an h3.... and you may get lucky and get a top plastic tank replaced at a radiator shop. I think I have heard one guy say he had it done. But as for the rest of us..... just replace as we had to. You can get one pretty cheap actually. Good luck either way.
Old 06-14-2014, 08:03 PM
a7m1's Avatar
Exclamation
well does it worth getting either part replaced top tank or whole radiator replacement?
maybe it can be fixed by welding or some sillicone
i'll probably try to look for the part if found for good price i'll replace if not foumd i'll try to fix
do you have any idea if the replacement is an enhanced part or the same core?
thanks, and good luck to you too
Old 06-15-2014, 09:49 AM
Old 06-16-2014, 02:16 AM
a7m1's Avatar
did the job, roughly 1 hour at independant shop
replced the plastic top tank for ~ 55usd (part + labour) and few more bucks for the coolant(unfortuntly used dexcool)
the part that i used has no letters written on it at all, it weigha about the same as the original
let's see how this holds up
BTW i am living in kuwait our summer this year is way too hot for hummer to handle i guess
also had 30 % shading film installed
thanks for the support
Old 06-16-2014, 06:39 AM
happythree's Avatar
Default thats a new one!
replaced the plastic top tank for ~ 55usd
Old 06-16-2014, 10:37 AM
a7m1's Avatar
yes exactly part + labour
other shops quoted close to this price
i have no idea how bad or good is this part
i don't recall the exact time but i would guess less than hour
shops here usually don't charge set price for labour
two guys worked on the car and i was the only customer at that garage at that time so they sfarted immediatly
Quick Reply: coolant leak !!!
