coolant leak !!!
3 Attachment(s)
so after a month of owning (what i assume carefully driven 2009 i5 hummer h3) not really sure about maintainance
43,500 miles while doing tb cleaning, after i wa done just topped up all fluids well, later smelled this funny coolant burning smell, ignored it, then saw coolant resercoir dropping ignored it too, since the weather is too hot and i overfilled it so i thought some evaporation and descardig of overfilling by that tiny hose or whatever, 3 days later still smill that funny smell, well it wasnt little coolant burning off due to filling the level is still decreasing and while the car still warming up, looked under the hood and its dripling(ac off) the leak was on the plastic peice on top of the radiator nextto the radiator yellow sticker warnings killed the car and went inside typig this thread !! puxtures in attachments so is this common failure??? the car didn't overheated thankfully |
sorry my image is not clear, captured usig mobile device( couldn't add arrows to indicate location)
here's pic i found on the internet showing the exact location http://www.carcomplaints.com/media/c...882b41c61d.jpg do they sell the plastic peice? as oem part? or the whole rdiator assembly has to be purchased? i assume this is common problem right? thanks |
# 1 next to tires. search and you will find hundreds of comments,,maybe thousands
(Post 313923)
my main question is weather that plastic leaking part sell standalone? or comes is assembly what do you mean #1 next to tires? forgive me that i didn't search i was really upset about this situation thanks alot :rolleyes: |
Number one replaced part on an h3.... and you may get lucky and get a top plastic tank replaced at a radiator shop. I think I have heard one guy say he had it done. But as for the rest of us..... just replace as we had to. You can get one pretty cheap actually. Good luck either way.
Originally Posted by BERULAKIDE
(Post 313934)
maybe it can be fixed by welding or some sillicone i'll probably try to look for the part if found for good price i'll replace if not foumd i'll try to fix do you have any idea if the replacement is an enhanced part or the same core? thanks, and good luck to you too;) |
Is 100 bucks a good price to you?
New Radiator 1 Quality Best Service w Lowest Price L Fit Both at MT 3 7 5 3 | eBay |
did the job, roughly 1 hour at independant shop
replced the plastic top tank for ~ 55usd (part + labour) and few more bucks for the coolant(unfortuntly used dexcool) the part that i used has no letters written on it at all, it weigha about the same as the original let's see how this holds up BTW i am living in kuwait our summer this year is way too hot for hummer to handle i guess also had 30 % shading film installed thanks for the support ;) |
thats a new one!
replaced the plastic top tank for ~ 55usd
(Post 313967)
other shops quoted close to this price i have no idea how bad or good is this part i don't recall the exact time but i would guess less than hour shops here usually don't charge set price for labour two guys worked on the car and i was the only customer at that garage :) at that time so they sfarted immediatly |
