Battery Suggestions
Old 11-14-2016, 03:20 AM
Broken Halo's Avatar
Default Battery Suggestions
It's battery replacement time in my '08 Alpha. Can I get some recommendations that people have had luck with other than going with a high end Optima? Thanks
Old 11-14-2016, 07:09 AM
ozark1's Avatar
Cool
My suggestion..and exactly what I did 5 years ago...Replace the battery cable ends..Buy a new OPTIMA !.."The bitterness of poor quality lasts long after the sweetness of low price "..a wise man once told me....
Old 11-14-2016, 07:34 AM
Might I suggest going with an AGM battery. We went with a larger size than stock with a lot more CCAs and reserve. Slight modifications to the bottom of the battery box are required (cutting) and a slightly longer bolt for the strap.
I will have to look at the group # after work.
Old 11-14-2016, 08:02 AM
Thanks Mark, but since I don't do any off roading, have a winch, or an aftermarket high power sound system, I am just looking for a reliable 'drop in' replacement. I know Sam's, Costco, Autozone, etc. all have their own brands, so other than another Delco I was wondering if there might be something as good.
Old 11-14-2016, 11:41 AM
happythree's Avatar
higher power is not needed for regular running. i ran mine on a lawn tractor small batt just to prove it.
i look at warr and buy the biggest that will fit from a z or wally.
actually i have 2 batts and glad i do when main goes dead i can jump from backup. great security.
Old 11-14-2016, 12:00 PM
Just get the OEM size AGM then. They last longer because they don't have plates in them.
Old 11-14-2016, 01:28 PM
Used to use those in my boat. Good batteries! Any brand suggestion?
Old 11-14-2016, 02:00 PM
A 12 volt battery brand....
Old 11-14-2016, 03:02 PM
"12 volt" ain't a brand.
Old 11-14-2016, 08:08 PM
Happy Hummer's Avatar
Do you folks in Michigan have farm and fleet stores?
I purchased both gfs and mine for both h3s there and they were the best ones they sold at the time. Platinum series. 3 years no hassle replacement. 7 years pro rated.
As batteries go they're pretty good. Exchange two or three times with no problems.
Under $99 for each one.
Quick Reply: Battery Suggestions
