Gobi Ladder ?
Old 02-01-2017, 08:04 PM
H2Miami's Avatar
Default Gobi Ladder ?
Just bought a Gobi ladder , checking the online instructions it shows a hole to be drilled .. Im not sure drilling a hole on the top is a good idea . Could anyone clarified if a drilling is needed , if so is there any treatment to avoid rust
Btw is there any roof rack which allow mounting on the OEM crossbars
THANK YOU
Old 02-02-2017, 10:59 AM
mcioci's Avatar
Expect tons of wind noise if you have sun roof open. I got rid of mine for this reason.
Old 02-02-2017, 02:01 PM
H2Miami's Avatar
You referring to the roof rack right?
In not going to keep it all the time. Just for road trips but yes wind nose may be something to considerate
Old 02-02-2017, 09:37 PM
H2Miami's Avatar
Just realized the hole is supposed to be dropped on the plastic trim top of the rear door
Old 02-03-2017, 11:44 PM
LoJac963's Avatar
I couldn't bring myself to drill the hole. I just used the single hole already there per the instructions. I've never had any issue and used to climb up the thing pretty regularly.
Old 02-04-2017, 01:12 PM
H2Miami's Avatar
That's a good thing to know
I'm been debating if drilling a hole or cancel the order . I will only use the existing holes then
Thx
Old 02-05-2017, 11:27 AM
LoJac963's Avatar
No problem. I may order a passenger side ladder for mine to have 2 ladders. Plus I think I'd need the upgraded lift supports since the stockers struggle with the one ladder.
Old 02-05-2017, 06:30 PM
H2Miami's Avatar
Good thing to know about the lifter. I may get another too . Do you know the part# for the upgrade lift
Btw it takes 4-6 weeks to get it. Gobi built it by orders
Old 02-05-2017, 08:48 PM
LoJac963's Avatar
GOBI Hummer H2 Rear Heavy Duty Hatch Spring Kit (Pair): Hummer Parts Club
Those are the heavy duty lift shocks. I can't believe the ladders are $220!
Old 02-05-2017, 10:40 PM
H2Miami's Avatar
How mucheap did you pay before
Quick Reply: Gobi Ladder ?
