Tire Pressure Sensor (Low Tire Warning)
Old 09-01-2010, 05:50 PM
psych0's Avatar
Default Tire Pressure Sensor (Low Tire Warning)
I had the little low tire light come on today and stay on saying 'Low Tire Pressure'. I stopped and had them checked and all were between 42 and 45 PSI.
I have had 35" tires for the last 4 months with no issues.
It appears that the spare Tire does not have a Sensor... can anyone confirm?
The tire shop thought the pressure may be too high since the recommendation state 30 PSI... and the 95 degree heat may have increased it even more... so he lowered the PSI to under 40.
My light is still on... Any issues with tire pressure sensors going bad?
What should I be running in 35's... I hate to have to increase the pressure to over 45 PSI but if thats what it needs with the larger 35's let me know!
Old 09-01-2010, 06:02 PM
Mr. Fancy Pants's Avatar
ours is going into the shop tomorrow for this....they suck.
Old 09-01-2010, 06:20 PM
slumlord's Avatar
I had my tires rotated about a month ago and the tpm message keeps coming up about two or three times a month. expecially on trips over 25 -30 miles
Old 09-01-2010, 06:27 PM
fharmon1's Avatar
According to the owners manual, the spare tire does have a sensor. Did you check the spare pressure?
Old 09-01-2010, 06:42 PM
Theuofmiami's Avatar
This has happen to mine and I just try to make them all 35. Sometimes you just need to give them all a little air and it might come on, but it will go off after riding in it for a good 20 miles.
Old 09-01-2010, 07:16 PM
psych0's Avatar
I upped the psi in each tire to 45 (35" tires) and the light stayed on.... Now I didn't drive it more than a mile back to the house.
I disconnected the battery and reconnected and the light is off.... for now.
Old 09-01-2010, 09:03 PM
gunsammo2's Avatar
Battery in sensor could be dead , the only problem is they're non replaceable and you have to buy a new one.
Old 09-01-2010, 09:30 PM
2wheelmonster's Avatar
how about getting nitrogen put in your tires??
Old 09-01-2010, 11:27 PM
drtom's Avatar
Banned
Default i think,,,
spare has sensor,not checked by system, only 4 rotating tires
i picked brains at walmart tires while back,they talked about a "rebuild pack" including batt
check it out at a tire shop
Old 09-02-2010, 12:36 PM
gunsammo2's Avatar
I wouldn't take anything to walmart they use impacts on the oil plug and strip them out.
Quick Reply: Tire Pressure Sensor (Low Tire Warning)
